Problem ripping FLAC and WAV in Foobar
Nov 30, 2007 at 4:55 AM Thread Starter Post #1 of 7
HiFi FOR METAL
I have been having issues ripping FLAC or WAV files into foobar2000. I have the latest version. I use two laptops and on one it works perfectly fine on, this is computer at work. However my computer at home will not let me rip any files, it always asks for me to find Flac.exe. I don't understand why this is because the other computer just worked without me finding anything. I know Foobar has an encoder. I would like to burn to 32 bit WAV if possible, but I can't seem to get it to work. Could someone let me know why this is?
Dec 1, 2007 at 7:49 PM Post #4 of 7
The problem is you're not using EAC.
I use and love foobar, but never in a million years would I rip with it, it is after all a media player. I have to object to the many ignorant people using iTunes, Winamp, WMP to rip CDs. They may rip, but doesn't mean they're any good...Jack of a lot of trades, Master of none.
Why is using an exclusive ripping program like EAC hard? Its a free download and as Overlord linked too, its a one-stop job to set-up.
To rip a CD:
Put CD in drive.
Open EAC...maybe wait for EAC to recognise it[seconds].
Press F5 to detect gaps[20 seconds] create non-compliant CUEsheet(with gaps) in new folder.
Press Shft-F6 to rip, in my case in 'Secure Mode' comparing CRCs, in 'New Folder'.
I use AccurateRip too.
Originally Posted by Log
Exact Audio Copy V0.99 prebeta 3 from 28. July 2007
EAC extraction logfile from 30. September 2007, 23:00
Bolt Thrower / Those Once Loyal
Used drive : _NEC DVD_RW ND-2510A Adapter: 0 ID: 0
Read mode : Secure
Utilize accurate stream : Yes
Defeat audio cache : No
Make use of C2 pointers : No
Read offset correction : 48
Overread into Lead-In and Lead-Out : No
Fill up missing offset samples with silence : Yes
Delete leading and trailing silent blocks : No
Null samples used in CRC calculations : Yes
Used interface : Native Win32 interface for Win NT & 2000
Gap handling : Appended to previous track
Used output format : User Defined Encoder
Selected bitrate : 768 kBit/s
Quality : High
Add ID3 tag : No
Command line compressor : C:\Program Files\Exact Audio Copy\FLAC\FLAC.EXE
Additional command line options : -8 -V -T "ARTIST=%a" -T "TITLE=%t" -T "ALBUM=%g" -T "DATE=%y" -T "TRACKNUMBER=%n" %s
TOC of the extracted CD
Track | Start | Length | Start sector | End sector
1 | 0:00.00 | 4:38.57 | 0 | 20906
2 | 4:38.57 | 3:41.54 | 20907 | 37535
3 | 8:20.36 | 4:41.09 | 37536 | 58619
4 | 13:01.45 | 4:03.58 | 58620 | 76902
5 | 17:05.28 | 4:14.46 | 76903 | 95998
6 | 21:19.74 | 4:15.22 | 95999 | 115145
7 | 25:35.21 | 3:10.51 | 115146 | 129446
8 | 28:45.72 | 5:18.63 | 129447 | 153359
9 | 34:04.60 | 5:27.32 | 153360 | 177916
Track 1
Filename D:\Music-NEW\Bolt Thrower - 2005 - Those Once Loyal\01 - At First Light.wav
Pre-gap length 0:00:02.00
Peak level 99.8 %
Track quality 100.0 %
Test CRC 56959782
Copy CRC 56959782
Accurately ripped (confidence 5) [04A4D9CC]
Copy OK...
...All tracks accurately ripped
No errors occurred
End of status report
Jan 15, 2008 at 10:11 PM Post #5 of 7
well man how can I NOT take advice from a dude who has melded Opeth's logo and his name in his avatar. Kudos on that by the way. EAC it is
Jan 16, 2008 at 2:40 AM Post #7 of 7
Originally Posted by OverlordXenu /img/forum/go_quote.gif
And follow this guide when using EAC:
http://www2.firehose.us:81/~jiggafellz/eac/index.html
Sure, it takes a little while to set up, but then it's extremely easy to rip a CD. Load a cd, do a couple keystrokes, make sure the track names are correct, and go! Then just leave it while it rips and encodes.
I feel unloved.
