jordannn15
- Sep 9, 2014
I have a Fiio X5 with a 128gb micro sd card and I can transfer music and everything perfectly but when I connect it to my car stereo via usb it displays: "NO AUDIO". When I check the manual of the stereo it says: "The usb storage device has security." and to fix the problem it tells me: "Follow the usb storage device instructions to disable security."
My question is how do I "disable security" so it will work with my stereo? This only happens to files that are .m4a (AAC) because I have used it before with it working fine via usb playing other files not from itunes such as mp3 320kbps files.
