Originally Posted by sbatth
darn... i just got a new car and would love to be able to play music from my ipod... ugh! damnit, why couldn't Apple get behind an "iPod your Benz" campaign?!?!
if you can afford a new benz, you can probably afford some direct connection with ipod and reciever. for a few reasons, i don't think the ipod your bmw is the best anyway, and it costs for example twice alpine's system, which i think is better.
there are only two ways to go for good dap sq in your car:
1. direct connect to stereo (you can do this usually with stock factory head unit, but better to get a new hu and get a cable (turns the cd changer input into a digital audio player input). for example, pioneer's is called a cd-rb10.
i've actually got one lying on the ground somewhere
2. if, and i do mean IF, you want to control the ipod (or other dap) from your in-dash reciever, there are a few ways to go. look at ipodlounge.com. alpine has probably the best system. it will cost you $100, and you have to hide the box somewhere, but then you can control the ipod from your head unit. personally, i much prefer controlling the ipod on it's own interface, rather than a reciever (i.e. option 1). however, the big plus for me is that this method will allow you to keep the pod out of sight (say, in the glove box), and you won't have to put it away every freakin time you leave the car. it also charges your pod (albeit weakly, it mainly just keeps the pod charged)
fm reicivers and tape deck connectors, wired fm modulaters and all the rest are just ez-fixes. try one and if you have an ear for audiophilia, you will be dissapointed.
if you need help installing a new head unit, or picking one and where to buy, don't hesitate to pm me. also check caraudioforum.com
