Textfeud
- Apr 28, 2012
So I have a very very weird problem. I can't get sound out of my Schiit Modi and Vali with my Macbook Air. Now here is the weird part. Both USB ports won't give sound. BUT both USB ports work just fine. I tried it with my active speakers and some usb sticks and everything works just as it should. Tried the Modi and Vali on my iMac and works great there. So that means: the Schiit Modi and Vali work and the USB ports on my Macbook Air work. It even recognizes the Schiit Modi when I connect it but NO SOUND. And yes the headphone is plugged in and I switched USB cables to see if that was the problem
What could the issue be and how can I fix it? Already tried the Option, Command, P, R reboot.
