Eagle_Driver
- Jun 22, 2001
Today I bought the "big brother" of the SL-CT590, the SL-CT790 (replacing my broken-down CT470). (BTW, the SL-CT790 that I'm reviewing is the version that's marketed in the U.S., with no line-out at all whatsoever.) So far, I think the headphone-out of the SL-CT790 sounds better than that of my Sony D-EJ1000 - the bass on the Panasonic is more articulate than that of my top-shelf Sony. And I heard virtually no difference in the Panasonic's sound with or without its supplied remote (unlike a lot of their other models with a remote).
As for using that Panasonic CT790's headphone jack as line-out, it sounded almost identical to the line-out of my Sony EJ1000 (except for loudness, of course).
Are there any weaknesses? Well, the headphone jack on the Panasonic CT790's remote (and also that of my Sony EJ1000) won't accomodate the plugs found on Grado headphones - the plastic grip is too wide for the plug to be inserted fully into those remote jacks. Some sort of modification is needed on those plug housings for them to fit the remotes' jacks properly. And the Panasonic defaults to S-XBS whenever the batteries are replaced - you'll have to press the EQ button on the remote (which, unfortunately, is required to access secondary functions on the CT790) three times to defeat the EQ. And speaking of the EQ, the only setting that's suitable for me is Off - the default S-XBS is overly boomy, Train mode is overly muffled and Live mode is overly tinny and echoey.
(The Sony D-EJ1000 and D-EJ855 also require their bundled remotes in order to access their secondary functions.) And speaking of default volume settings, Panasonic's default is 10/25, so you can at least listen to music with efficient headphones; the Sony's default setting is an extremely low 3/30.
Overall, I'd rate the Panasonic SL-CT790 slightly above the Sony D-EJ1000 - and both are among the best performers of the currently available (read: current model) portable CD players.
Randy a/k/a Eagle_Driver
