Trevayne10
- Jan 15, 2015
For any of you inveterate owners of the Panasonic RP-HTF600-S:
Here are my APO Equalizer settings (using the excellent PEACE GUI) to hit the "Golden Ears" target for the Panasonic RP-HTF600-S:
Two .jpg images RP-HTF600-S_GET.jpg (960x768) and RP-HTF600-S_EQ.jpg (1586x689)
Top image (RP-HTF600-S_GET.jpg) ("GET" = "Golden Ears Target") shows the ideal spectral pass for "Golden Ears Target" of Panasonic RP-HTF600-S over-ear Headphones
Bottom image (RP-HTF600-S_EQ.jpg) shows my (fairly exhaustive, and very rough) EQ adjustments to the RP-HTF600-S headphones to match the "Golden Ears Target", using the excellent APO Equalizer and PEACE GUI - changed and added 3 new frequency centers (based on 1/3 octave profile). May be a tad bright for some. Of course, your feedback is most welcome -
Enjoy!
- Trev
Not sure if this will be helpful, but you can scrape the following "Peace.txt" settings, and copy/paste & save it into yours:
Channel: all
Preamp: 14 dB
Filter 1: ON PK Fc 20 Hz Gain -2 dB Q 4.32
Filter 2: ON PK Fc 25 Hz Gain -2.5 dB Q 4.32
Filter 3: ON PK Fc 32 Hz Gain -5 dB Q 4.32
Filter 4: ON PK Fc 40 Hz Gain -6 dB Q 4.32
Filter 5: ON PK Fc 50 Hz Gain -7 dB Q 4.32
Filter 6: ON PK Fc 63 Hz Gain -8 dB Q 4.32
Filter 7: ON PK Fc 80 Hz Gain -8.5 dB Q 4.32
Filter 8: ON PK Fc 100 Hz Gain -8.5 dB Q 4.32
Filter 9: ON PK Fc 125 Hz Gain -8.5 dB Q 4.32
Filter 10: ON PK Fc 160 Hz Gain -8.5 dB Q 4.32
Filter 11: ON PK Fc 200 Hz Gain -8.5 dB Q 4.32
Filter 12: ON PK Fc 250 Hz Gain -8 dB Q 4.32
Filter 13: ON PK Fc 315 Hz Gain -8 dB Q 4.32
Filter 14: ON PK Fc 400 Hz Gain -7 dB Q 4.32
Filter 15: ON PK Fc 500 Hz Gain -6.5 dB Q 4.32
Filter 16: ON PK Fc 700 Hz Gain -5 dB Q 4.32
Filter 17: ON PK Fc 800 Hz Gain -3 dB Q 4.32
Filter 18: ON PK Fc 1000 Hz Gain 1 dB Q 4.32
Filter 19: ON PK Fc 1250 Hz Gain -3.5 dB Q 4.32
Filter 20: ON PK Fc 1600 Hz Gain -5 dB Q 4.32
Filter 21: ON PK Fc 2000 Hz Gain -5 dB Q 4.32
Filter 22: ON PK Fc 2500 Hz Gain -2 dB Q 4.32
Filter 23: ON PK Fc 3000 Hz Gain 3 dB Q 4.32
Filter 24: ON PK Fc 4000 Hz Gain 6.5 dB Q 4.32
Filter 25: ON PK Fc 5000 Hz Gain 5 dB Q 4.32
Filter 26: ON PK Fc 5400 Hz Gain 7 dB Q 4.32
Filter 27: ON PK Fc 6000 Hz Gain 4 dB Q 4.32
Filter 28: ON PK Fc 7000 Hz Gain 2.5 dB Q 4.32
Filter 29: ON PK Fc 8000 Hz Gain -3 dB Q 4.32
Filter 30: ON PK Fc 15000 Hz Gain 5 dB Q 4.32
Filter 31: ON PK Fc 20000 Hz Gain 13 dB Q 4.32
Enjoy!
- Trev
Channel: all
Preamp: 14 dB
