organic io
- Oct 19, 2015
I'll be posting this review in several parts as I go... Here's part 1
Headphone comparison: Philips SHP9500 vs Superlux HD681 vs Koss KSC75
Songs I have selected to do the testing with:
Dave Matthews Band - Satellite
Goldie - Timeless (section in the middle)
Nirvana - Smells Like Teen Spirit
Chicane - Saltwater (section in the middle)
keith303 - Last Movements of a Drowning Smurfbaby
Darius Rucker - Wagon Wheel
I have chosen these songs because they are all great songs, but also because they have lots of dynamics which should be good for headphone testing and comparison.
Also, I have extensive experience with Sennheiser HD590, but I am not able to directly compare them because they died. So I will probably mention them at times.
1/30/16 2:11pm preliminary testing.
Comfort
Koss KSC75's - Decently comfortable, though the clips tend to get irritating on the ears after a while.
Superlux HD681's - Comfortable. I have a moderately big head. In order to make these more comfortable, I essentially bent the plastic to make it larger and fit my head better. Works great. Not nearly as comfortable as the Senn HD590's were, but not bad at all.
Philips SHP9500 - Upon initially putting them on, I'm a bit confused here. Practically EVERYWHERE I read online said these are some of the most comfortable headphones they have ever used. That they are so light they are practically un-noticeable, and also that there isn't much clamping force. Unfortunately I'm not feeling the same love for them right now, they feel noticeably less comfortable than the Senn HD590's were.
The clamping force is noticeable. I've tried several settings. Currently I have the headband set on "5". I might do some bending of the headband on these to improve comfort. But before I start to destroy them, I want to give them a couple hours test to see how they do.
Settings
Audio interface: Alesis io2 express
Headphone mods - KSC75's have a variant of the Kramer mod. SHP9500's and HD681's have no modding at this time.
Koss and Philips with no EQ, Superlux with some EQ settings in Windows with Equalizer APO 1.1, according to this guy's recommendations:
http://www.amazon.com/gp/customer-reviews/RPZSVYG1QBUQ/ref=cm_cr_pr_rvw_ttl?ie=UTF8&ASIN=B002GHIPYI
Song tests
1st song test: Dave Matthews Band - Satellite
Koss KSC75's
I know this song well, and I know the Koss KSC75's well. This is a sound signature that I know and love. But can it be improved upon?
Everything is blissful, if a bit bright. Otherwise the mix is well balanced.
Superlux HD681's
Sound is acceptable, though the mix sounds a bit muddy or muffled. Bass is slightly booming, probably due to EQ settings. Ride cymbals sound amazing.
Philips SHP9500's
Wow, just wow! You can hear little details in the guitar plucking at the beginning that aren't even audible on the other 2 headphones. And it's not just because I'm "listening harder". The cans are incredibly revealing. Overall the bass is adequate (I've heard some say they are bass lacking). Everything sounds slightly bright, I might need to EQ it down later, but it's quite nice and shimmery.
In this initial song test I can say the SHP9500's definitely compete with the Senn HD590's and possibly exceed them. I can definitely see how people are comparing them to HD600/650's (though I've never actually used those myself)
Stay tuned for more song tests and SHP9500 comfort testing
Comfort
Settings
Song tests
Koss KSC75's
Superlux HD681's
Philips SHP9500's
