kafelnikov
- Feb 10, 2016
Hi there,
I am about to order a new pair of headphones and I was wondering if you could help me with a problem I have had for quite some time with my soundcard (Presonus Audiobox USB), I use the audiobox only with my speakers because when I plug my headphones in they sound like total crap (which it doesn't happen when I use them with the integrated realtek soundcard inside my laptop, they sound beautiful there), basicly it sounds like there's a sort of high pass filter that completely ruins the sound, giving it a sort of harsh ''electrical'' quality to it, and losing all bass of course. I had posted about this problem in the presonus forum actually some time ago, this is the thread if you want to read about it: https://forums.presonus.com/viewtopic.php?f=164&t=7100&sid=9a98d2416120eae9ce269236fb9355d7
As you can see a guy there suggested me that it was likely a ohm mismatch between my headphone (32 ohm) and the headphone amp of the audiobox (those are the specs of the audiobox headphone amp: 60 mW/Ch @ 60Ω Load) that caused that hpfilterish sound. I was wondering if you think this is the root of the problem and that if by ordering headphones with a higher ohm impedance than 32 ohm that would solve the problem.
thanks for your attention
cheers
cheers
