legolas52
- Dec 26, 2005
I was thinking of buying an KSC-75. I heard they are good, on the forums here. Are they? How much bass do they have? I have an x5 which gives a ton of bass, and I don't like bass much. I want just a little. Are they overlly full w/bass? Also, are they right-angle?
I was also thinking of buying some earphones. What do you suggest? I'm in the "cheapo" range: under $30. I don't really like ear plugs when they go INTO your ear. Some which go in a little are ok, but I prefer just normal earphones. What do you reccomend? What do you think of the Sennheir 400/500?
Thanks a lot-for helpin' a noob.
