- Feb 1, 2011
*NEW* RAL-1648iP1 - Digital Music Data Converter - $299
Turn your iPod or iPhone into a high-end audio system with the RAL-1648iP1!
Digital Music Data Converter for iPod/iPhone/iPad.
Fully compatible with 30P Dock connector equipped iPod/iPhone.
Fully compatible with Brand New Lightning connector equipped iPod touch 5th, iPod mini 7th, iPhone 5, iPad 4th. and iPad mini.
Just hook up with Apple Lightning – USB cable or 30P dock connector –USB cable.
S/PDIF Digital Audio Output, Coaxial and Toslink/Optical for Audio System.
Two independent X-tal Audio Master Clock oscillators (22.576MHz and 22.5792MHz) generate precise S/PDIF Digital Audio output signal.
Low ripple and spike noise powerful AC adapter provides enough power to charge iPod/iPhone/iPad(2nd or newer).
Ready for Apple Remote, provides same function as iPod Universal Dock.
Elegant design matches to High-Fidelity Audio System.
*NEW* RAL-DSDHA1 USB DAC - $1000
Free Shipping in the U.S.!!
The RAL Audio Products DSD and HD-PCM(24/192k) ready USB DAC.
Ready for DSD64 and High Density 24bit / 192kHz PCM.
Compatible with your favorite Music Player.
Just Plug & Play with Windows PC and Mac.
Excellent Digital circuit design and firmware.
High quality and high performance Analog circuit.
Powerful Power Circuit supports powerful sound.
*NEW* The RAL-DSDHA2 - $2000
The RAL-DSD and HD-PCM(24/192k) ready USB DAC with Balanced Headphone amp.
Moon Audio is now Proud to be a Dealer of RAL Audio Products:
the RAL-1648iP1, the RAL-DSDHA1, and the RAL-DSDHA2.
Ral Audio Products are made by RATOC Systems International which is the US subsidiary of RATOC Systems, Inc., and is one of the leading PC card/PCI board companies in Japan and has over 20 years of experience in PCMCIA products and PCI interface boards.
Thank You.
Drew Baird, P.E.
Moon Audio
Moon Audio
140 Iowa Lane
Suite 204
Cary, NC 27511
919-649-5018
drew@moon-audio.com
919-649-5018
drew@moon-audio.com
Follow us Today!
Stay updated on Moon Audio at their sponsor profile on Head-Fi.
