beachbum5397
- Jul 8, 2013
After having to send back what appeared to be a defective Creative Titanium HD soundcard, I thought I would give the ASUS Xonar Essence STX a try. I got that card today but now I'm stumped. After opening the package I find out that the card has to be hooked to a power source but no cables came with the card for same. I see the connector is a 4-pin type and I remember seeing those in my old Dell PC, but it looks as if the cabling in my HP Pavillion p7 1210 uses all SATA cables. The only wire I see that might remotely fit is one wire that would probably provide power for a second CD-ROM, it's a black connector, but even there I don't have anything that mates that to a 4-pin white connector. My computer uses a Holley motherboard and I see that there are a couple of what look like open SATA connectors almost in the very middle of the motherboard, but since I'm legally blind I cannot really tell that deep in, just what I'm seeing. Can anybody who might be familiar with this computer tell me if there's another spot I should be looking for to provide power for this soundcard? As I said the only thing I see is a cluster of four little connectors, two of which are used, and they all appear to be different colors but feel the same. I really don't want to have to take this in to a computer shop just to have them hook up the sound card, if I can help it. Gee, the titanium didn't require power like this, not that I know of, but had too many problems with the Titanium to go over it again. If this card won't work, will have to resort to a Xonar DGX card and will just have to content myself with it unless I want to pony up for a good USB card.
One other thing, where do I get these Uni Xonar drivers from? any help appreciated. Please write me directly if you can, at powersradio1@charter.net. I am finding it most difficult to navigate this site which is not behaving well with the screen magnification software I use that blows up everything on screen to 6X. It requires a lot of mousing to go from left to right on the screen and as I type this post the cursor is not auto-panning meaning I must stop and move the moouse over every few words to see what I'm typing or else type blind. This is one of those sites that is not accessible for a visually impaired person, and I hope that will change soon.
Thanks for any help.
Bill
Bill
