Need help with digital output on Xonar DG (no sound)
Feb 20, 2014 at 6:54 PM Thread Starter Post #1 of 13
PascalT
My digital output from Xonar dg won't work - there's no sound at all. Can anyone help?
- Latest drivers
- Light out of the port works
- Normal non-SPDIF output works
- Control panels: http://imgur.com/AXiuMHM
- I've tried WASAPI and DS in foobar
I'm stumped here.. :) thanks in advance.
Feb 20, 2014 at 9:05 PM Post #2 of 13
  My digital output from Xonar DG won't work - there's no sound at all. Can anyone help?
- Latest drivers
Try disabling the motherboard's on-board audio, in the BIOS.
Feb 20, 2014 at 9:19 PM Post #3 of 13
Tried it already before with no results.
Feb 20, 2014 at 9:41 PM Post #4 of 13
Do you have the Xonar Audio Center GUI installed? There is an option in there to enable the optical out. The SPDIF Out box needs to be checked, and PCM chosen on the dropdown next to the box.
Feb 20, 2014 at 9:59 PM Post #5 of 13
I can't find the download link for it anywhere. I looked for a while.. any clue? :)
Feb 20, 2014 at 10:15 PM Post #6 of 13
Try here:
http://support.asus.com/download.aspx?SLanguage=en&m=Xonar+DG&os=30
The Audio Center may be in the package with the drivers.
Feb 20, 2014 at 10:20 PM Post #7 of 13
You're right. thanks. When  I run the app it says "No Xonar Device found". It shows in my Device Manager though.. Hmm.
Feb 21, 2014 at 1:17 AM Post #9 of 13
Tried the unified drivers, still same issue.. ugh. I guess the card is broken somehow, even if it's new.
Feb 21, 2014 at 1:28 AM Post #10 of 13
Update: tried the "stable" version Unified drivers and finally got access to the control panel.. indeed SPDIF had to be enabled there for the sound to work. I couldn't access it with any other drivers.
thanks for the help.. now I can live in peace again ;)
Feb 21, 2014 at 1:31 AM Post #11 of 13
Glad it worked out. Now it's time to enjoy music, since that problem is behind you.
Feb 21, 2014 at 1:33 AM Post #12 of 13
According to the picture you posted, it looks like the Realtek audio is still enabled?
Feb 21, 2014 at 1:46 AM Post #13 of 13
You can have more than one audio source enabled, but need to designate which one Windows is to use. The long way to switch which one you want to use involves going through Control Panel and navigating through the settings.
Or, I have found a handy little program to use to switch audio - https://code.google.com/p/audioswitch/
This can be placed in your start up folder or taskbar for quick access. It has worked great for me.
