Steve Karl
Greetings!
I need some cable to replace a rotted original cable on a set of AKG K240 Monitor.
The OD of the original cable is approx 3.45 mm and is just a 3 conductor cable with no wrapped shield.
I have the little rubber strain relief split up to the part that goes under the cap and would like to use that
so it's kind of important that is get something very close to 3.45 mm.
Can anyone recommend some cable that is closer to 3.45 mm?
Thank you!
Thank you!
