dougwx12
- Jun 13, 2005
Hmm, well, I admit that I only use my APX's for 16/44 stereo. But, I know that it supports DTS streaming just fine, which I thought was much higher than your above limits by default. In fact, I don't think those rates mean anything until you hit a DAC?!? I was under the impression that it was a bit passthru at that point.
The AppleTV would also be an expensive version of the same, but I'd be shocked if the APX was different.
Originally Posted by schaqfu /img/forum/go_quote.gif dougwx12: Yeah, I really like the Airport Express option too, with its optical out; the only problem is iTunes (as far as I have been able to tell) supports files at higher resolutions than the AE is capable of putting out -- basically I think the Airport is limited to 16 bit and maybe up to 48Khz, in which case I'm just as well off using the USB connection direct to my DAC anyway. But that's exactly the kind of setup I'm looking for, bit pure output; just need one that goes higher. |
