Alright, time to revive a dead thread!
I've been having some issues with scratching noises on the right channel of my Mosfet-MAX that tube swapping did not solve, but that seemed to be alleviated by jiggling the right tube around in its socked. The tube socket contacts appear to be pristine on both sides so I don't believe that's the problem. I figured I might want to check the tube bias and it was completely off from what I'd set it years ago. I corrected it and checked the MOSFET bias while I was at it and to my surprise, the right MOSFET showed some odd behavior: The bias voltage measured differently depending on which reference points I used. I proceeded to reflow the MOSFET joints as one of the transistors seemed to have some pretty bad cold joints, and I also cleaned the PCB again. Now, the cracking/popping noise is even worse and it doesn't change no matter how I move the tube around. Is this a shot MOSFET, or did I somehow make the cold joints worse? They are looking decent now, nice and shiny, although there's way too much solder on some of them - my soldering iron is currently semi-broken (snapped in two a few days ago) so I can't use solder wick properly.
Edit:
Alright, that was pretty unnecessary - I had another look at the leads of the MOSFET I suspected was causing the noise and on the component side of the PCB, they were encrusted with some gross-looking flux residue. I scraped it away and now the amp's dead quiet again.
