- Mar 29, 2003
[size=x-small][size=x-small]We have been getting a lot of positive response and request a for more information on the Moon Audio Silver Dragon Version 3 Headphone replacement cable for Audez'e LCD-2 headphone. [/size][size=x-small]Hence the reason for this post to provide more info on the new Version 3 cable.[/size][/size]
[size=x-small] [/size]
[size=x-small][size=x-small]The new Version 3 Silver Dragon cable uses 4 x 99.99998% UP-OCC Stranded Silver 24AWG Teflon insulated stranded conductors. The previous version used 4 x 99.998% Ultra Pure Silver 24AWG Teflon insulated stranded conductors. Thus we have stepped up the purity to the purist available by today's technology.[/size][/size]
[size=x-small][size=x-small]We have improved the conductors properties over the previous Version 2 cable as these conductors are free from impurities and have virtually no crystal boundaries. The conductors have almost no distortion compared to ordinary silver conductors.[/size][/size]
[size=x-small][size=x-small] [/size][/size]
[size=x-small][size=x-small]Each conductor is made up of a special varying sized stranded geometry. The silver stranding's are mixed with Kevlar standing's to reinforce the conductor. Making it stronger overall and less prone to failure due to the harsh constant flexing that headphone cable experience.[/size][/size]
[size=x-small][size=x-small]Each conductor is encapsulated in a Teflon casing.[/size][/size]
[size=x-small][size=x-small]The conductors are then surrounded by cotton and a thin layer of Aluminum Foil.[/size][/size]
[size=x-small][size=x-small]It is then protected by a 100% coverage silver plated copper secondary shield and placed in a polyethylene jacket for further protection. [/size][/size]
[size=x-small][size=x-small]To improve it's flexibility we are no longer using a Techflex jacketing as we did with our previous versions.[/size][/size]
[size=x-small][size=x-small]A variety of connection options are available for your downstream connection. Such as the mini plug, RCA, XLR and a whole host of others. We custom build these in house to your connection specification.[/size][/size]
[size=x-small][size=x-small]The cable can be used in either a single ended or balanced design. The wire is soldered to a connectors using high quality Cardas silver solder.[/size][/size]
[size=x-small]Pricing:[/size]
[size=x-small]5ft Cable with 1/4", mini plug or 4pin Male XLR $250[/size]
[size=x-small][size=x-small]10ft Cable with 1/4", mini plug or 4pin Male XLR $300[/size][/size]
[size=x-small][size=x-small]15ft Cable with 1/4", mini plug or 4pin Male XLR $350[/size][/size]
[size=x-small][size=x-small]25ft Cable with 1/4", mini plug or 4pin Male XLR $400[/size][/size]
[size=x-small][size=x-small]Add $25 for Dual 3pin Male or Female XLRs[/size][/size]
[size=x-small][size=x-small][size=x-small]Add $125 for Dual 3pin Male Rhodium Furutech FP-601 XLRs [/size][/size][/size]
[size=x-small]Add $150 for Dual 3pin Female Rhodium Furutech FP-602 XLRs[/size]
[size=x-small]Stock 1/8" plug is a Neutrik. Soon to be the Rhodium over Silver [size=x-small]Oyaide Connectors[/size][/size]
[size=x-small][size=x-small]Stock 3pin and 4pin Male XLRs are Neutrik[/size][/size]
[size=x-small][size=x-small]Stock 1/4" is the Furutech FP-704[/size][/size]
[size=x-small][size=x-small][/size][/size]
Stay updated on Moon Audio at their sponsor profile on Head-Fi.
