magicalmouse
I wonder if anyone has any thoughts on these - do they actually improve the stock firmware in any way and if so can you identify the improvements?
I have Fidelizer installed on my iBasso R10 (DX100) and DX150. Both daps sound noticeably better and the R10 is much more responsive (faster).
I also tried Lurker's firmware add-on and it has some optimizations that smooth out the OS. Can't say it sounds any better than stock but it does add the Google Play Store.
Both software mods also port apps and modes from other players like running DX220 versions of software on a DX150/DX200. Stability seems about on par with stock but the added sound quality and/or features are the main draw.
You'll need to try them to see and hear any improvements for yourself though. Just make sure you're comfortable flashing firmware using a PC. Installation isn't difficult but may be a bit frustrating to users who aren't familiar with software mods.
