philodox
- Dec 12, 2003
*SNIP* [Removed quote]
If you want to look at the specs of my ONEAC, follow this link. It is the CP1105 model.
So anyways, I figure that changing the screws, removing the circuit board, doing a rewire and installing the auricaps should not be all too difficult.
I also bought a hospital grade wall outlet and was thinking about pulling the two outlets from the ONEAC and installing it in their place. I only need to plug two devices into it anyways, so I can leave the other slot empty [or perhaps hardwire some Quail PC's there].
I figured that I could pull the stock power cord from the ONEAC and replace it with a Quail PC as well. I plan on removing the ferrites from my Quail PC's that I will be using with components, but should I leave the ferrites on the one on the ONEAC? Biggie mentions that his higher end ONEAC has a ferrite somewhere, would I get the same effect if I left the ferrites on the cord? I know that people say that ferrites limit dynamics and such, but will this be an issue if the ferrites are in between the wall and the power conditioner?
Any suggestions or ideas would be welcome. I will probably try to mod it this weekend. I still need to get the auricaps off of Biggie though, so I will probably do that part later.
Thanks in advance,
- Jason
Thanks in advance,
- Jason
