Originally Posted by theScribe /img/forum/go_quote.gif
So just a rehash. This will be my new setup.
Goldring MM GX1042 Cartridge -> Music Hall MMF5 -> Cambridge Azur 640p Phono-Pre -> Audiotailor Jade (Sylvania BP 5751, RCA 6AS7G) -> Sennheiser HD650 Stock.
I heard the goldring is slightly warm with the table, the 640p a little cold, so i'm guessing the warmth of the Jade and the HD650 will balance it out?
-JC
The most effect on tonal balance will come from the cartridge and the headphones/speakers. The preamp and amp will have some effect, but it will be smaller. I don't think that the tonal balance will change much from what you experienced prior to adding the turntable.
I ordered a Goldring 1042 replacement stylus for about $210 from Mantra Audio UK.
I been reading about tuning the table, VTA adjustment, using the protractor to align, setting tracking force, tying on an anti-skating weight, putting playing cards under the TT to stabilize it, etc etc. This is much more complex than I thought, how minute (or extreme) will the sound change making these "little" adjustments?
Born in a world of digital and CDs, this is like DIY burger king "have it your way" of music. LOL.
-JC
Before you make any other adjustments, your table
has to be level.
VTA for any elongated profile stylus (which yours is) is very important. If it's not aligned properly, you could experience sibilance, noise, poor tracking and tonal imbalance. Hopefully the cartridge was aligned properly originally and you will just have to plug in the new stylus without having to make any further adjustments. Double check with a protractor to make sure that it looks aligned, especially parallel to the lines on the protractor. VTF will have some effect on the stylus rake (how close to perpendicular the stylus is to the record), so any other adjustments can be done after you set VTF.
The VTF for your cartridge is 1.5g to 2.5g. If your cartridge is aligned properly, then a lighter tracking force will cause less wear and tear on your records. However, the VTF will affect your stylus rake angle. More VTF will cause the tail of the the cantilever to drop, emphasising the bass. Less VTF will cause the tail of the cantilever to raise, emphasising treble. My feeling is that I would not exceed 2.2g and would probably track at about 2g. You will have to experiment with the VTF to get the sound you want. if you don't have one already, you should get a stylus force gauge like a Shure SFG2 for accuracy.
Anti-skating affects tracking. If it is not set properly, it can emphasise noise by scrubbing one wall of the groove. It will also throw off your channel balance. It may also cause damage to the record by wearing one wall of the groove. Over the long term it will probably bend your cantilever.
One other accessory that you should have is a carbon-fibre brush like an Audioquest. This will pick up dust just prior to playing the record, making the record quieter and causing less damage (pops and clicks).
Post if you need further explanation or advice.
