Low volume of my PS Vita, any way to boost it?
Mar 25, 2013 at 1:22 PM Thread Starter Post #1 of 2
jamieuk147
I have some sennheiser momentum headphones and notice the volume is pretty lacking! and even without the headphones plugged in, volume is kinder low.
I do own a colourfly C4 player and wondering if there was some way to use this to boost the volume and impact with headphones on, or something else I can buy ?
Thanks!!!
Mar 25, 2013 at 6:32 PM Post #2 of 2
Thanks!!!
Guess the power is dedicated to the device itself so you can keep on playing w/ out killing the battery fast. Like an iDevice. Except those have limiters for sure.
If the c4 has a line in, you can do a 3.5mm -> 3.5mm cable to make it so that it feeds the audio into the c4 and then to your headphones I think. Or you could by a standalone amp like the o2 that has a 3.5mm TRS plug input, which you'd use the 3.5 to 3.5 the same way you would if your c4 has an input.
