What kind of cable do you need?
There are many different types, gauges, etc...
If you just need good, 'cheap', shielded cable, then your best options are Sommer Cable or Mogami.
And if you want a fabric sheath, you need to find a wide gauge of paracord and pull out and discard the inner cords.
If you want something that looks good like silver plated copper, things get very expensive very quickly and I don't know where to start with that overpriced junk.
To give a bit more detail, I'm going to replace the normal way a sennheiser hd 598 hooks up
I think the official cable is a bit to expensive, and the replacement cables made for it are to fragile due to the way they are potted and how inflexible the wire is, it caused flexion damage which either has killed the audio entirely, or has made certain frequencies drop out, the current cable i'm using seems to drop out the lower 500hz at random.
what i'm looking for is something that's relatively easy to work with, I don't want a hard sheathed cable, due to how close the jack is to my neck it becomes a point where the cable is bent at angles fairly easily, and is why I think I had 4 replacement cables die on me. I'm not going to be able to explain this in a way that isn't weird so bear with me. I would like a cable that if I extend my fingers like I want to karate chop something, if I rest the cable on top it drapes over my fingers, I have several extension cables, and even guitar cables that are this malleable, the original sennheiser cable was also this way, but I also have a few cables that are very stiff and the sheath on them is either plastic mesh, or is a hard plastic sheath that feels kind of like.
now that you mention it though, paracord sheathing... I could buy some silicone wire, probably 50 or so foot spool, maybe a spool kit with colors to make it easier on me, and some paracord and completely make my own wire and not use something pre made... that would cost a bit more but something completely custom to my needs. that's in my considerations pile now.
just so you know what I was considering
https://www.aliexpress.com/item/Aip...8.0&pvid=65a2bb2e-645a-4dcf-970c-4a9603ac4929
its 20 meters of cable, and I don't think I would use more than 3-4 maybe up to 6 and when damage happened at either end, I would just snip the ends and re solder, given it seems that ready made cables last me around 2-3 months before damage happens, I think I could go years with this and be fairly happy if I knew for a fact it would work, the seller told me it's likely not what i'm looking for, here I'll post exactly what I asked them
"Hello, I'm looking for wire to fix my headphones.
This wire looks like it fits my needs exactly.
However I can't tell what inside wires are.
are they sheathed at all?
are they enameled?
are they seperated by the outer tpe?
Because of the time it takes to get things shipped to me, I want to make sure im buying the right thing beforehand.
Thank you in advance for any reply."
with a bit more info any suggestions? i'm trying to consider all my options, and just for the sake of mentioning, yes I tried using 2.5mm to 3.5mm adaptors, but nearly all of them are garbage, I have dissassembled one of the ones that broke and there may be something I can do to make it better but its a shot in the dark honestly.
