rueyloon
- Jan 21, 2005
Hello
After years of looking from the sidelines, I got a Alessandro MS1 from Jaben (a local store in Singapore) last a few days ago.
I was using the Panasonic retro HTX7 looking headphones but the pad had started to peel so it's a great time to spend some money
I had a great session at Jaben picking out the headphones. There was definitely an appreciable difference between the GR60 and the MS1. The GR60 sounds too neutral to me while the MS1 is definitely more musical.
Now here is the problem, I've never had an open can before and I'm getting them for use during commuting to work and also for use in my office. I guess I didn't understand why people usually don't recommend this type of cans for outdoor use until I experienced it for myself. There is just too much
sound leaking inside. It really distract from enjoying the music. The MS1 sounds great, but they need to be used in a quiet environment.
So here's the question, are there any closed cans with circumaural design that I should take a look at ? I hope to narrow down my choices to around 3 then I can go for another audition at Jaben
hope you guys can give me some nice suggestions.
Cheers
![smily_headphones1.gif](http://www.head-fi.org/forums/images/smilies/smily_headphones1.gif)
Cheers
