mikeypas
- Jul 18, 2016
Hi! I'm using a dual 3.5mm to XLR balanced cable for my Hifiman headphones (from Hart Audio Cables)
I would like to get a longer cable, maybe around 15 feet.
Would it be best to get a new dual 3.5mm to XLR balanced cable that is 15feet long, or would it be acceptable to get a female 4pin XLR to male 4pin XLR as an "extension cable" ?
Would that reduce the sound quality vs a single cable? Would the extension maintain the "balanced" aspect of the cable?
I actually am not finding a 4pin XLR male to female easily, so would be open to some suggestions.
Thanks!
Thanks!
