Mar 4, 2025 at 11:40 PM Thread Starter Post #1 of 2
eddy0969
México
Hello There, a Newbie here , I recently purchased the kefine clean IEM and I’m very happy with this adquisition. For comparison purposes I must tell I also own the SIVGA QUE and I think the Kefine is a marvel for the prize tag. Of course the bass response its not so energetic as with de SIVGA QUE but I think the overall result its pretty good. Ive just upgrade the Kefine clean cable with the linsoul tripowin C-01 with 4;4mm terminal, For amplification purposes I use the alegro mini and also the FiiO Q3, both can handle 4,4mm, I’m pretty new to this audiophile World but I think theres a subtle upgrade. Do you guys that are more experienced in this issues think changing the cable its a good upgrade? What should I expect from that? Thanks in advance
Mar 5, 2025 at 3:15 AM Post #2 of 2
Cable swaps can change an iem's sound but it's better to invest in the perfect iem (for you) first, then the cable becomes a tweak.
