kanto yu5 vs kanto yumi vs audio engine a5
Jun 16, 2016 at 7:42 PM Thread Starter Post #1 of 5
jp123
requirements for my speakers.
1) bass!!! love bassy speakers
2) bluetooth connectivity
3) for my PC setup
4) space saving
5) as little cables as possible
should i get the YU5 or YUMI or A5
Jun 16, 2016 at 11:35 PM Post #2 of 5
Monoprice 5" studio monitors, $170.79
http://www.monoprice.com/product?p_id=605500
Jun 21, 2016 at 10:41 PM Post #4 of 5
The AudioEngine A5+ are simply amazing, yes I have them cleaned with an ifi iUSB + ifi ipurifier and a Audioengine D1 DAC. It's almost better than my high end 2 channel system, really!!!!!!!!. The soundstage and bass is outstanding.
I would too be interested in hearing the KANTO Yumi, as I have heard great things from this speaker. Only drawback I can see is the lower wattage that the Yumi (30w per channel) than the A5+ (75w per channel). Sounds like you need the bluetooth, so maybe the Yumi's or AudioEngine big brother the HD6 (has bluetooth).
Good luck
Jul 8, 2016 at 10:53 PM Post #5 of 5
I wouldn't let bluetooth be too much of a determining factor, seeing as you can get a BT (and/or Chromecast audio) receiver for $20-30 bucks. Sure, better and convenient for it to be built-in, but then again BT is continually being updated (SBC --> aptx --> aptx-HD, 2->3->4->???) so dongles can later be upgraded too unlike speaker components.
The A5+ lacks built-in BT but has a USB-powered port, perfectly suited for a BT dongle (if you're not using it to charge a phone).
