lmf22
- Oct 16, 2006
From what I understand, JRiver's internal volume control (set to "Internal," not the other options) are processed at 64-bit. And for every 6db reduction, I would lose 1-bit of resolution.
Does that mean I can safely down the volume by maybe -24db without losing any of the resolution in my music (even with 24-bit music)? Also, it is better to attenuate by 6db intervals (-6db, -12db, -18db, -24db, etc.)?
I ask because at full volume (100%, or disable volume control) in JRiver, the signal is too loud, and I do not get much range on the volume knob on my integrated amp. It is a problem because I usually play music at a low volume (around 70-75db).
