Is there a battery-powered USB DAC that can charge a phone while also converting data?
Feb 21, 2022 at 9:16 AM Post #2 of 7
FiiO E18 Kunlun--not sure if it will charge and output simultaneously. There might be other ready-made options, or you could DIY one with a splitter of some sort.
Feb 23, 2022 at 12:42 PM Post #3 of 7
The original iFi Micro iDSD Black Label has usb input for audio, and a separate USB output exclusively for charging other devices from its internal battery. It’s charging output isn’t very high though, so the connected device’s battery may still drain—just at a slower rate.
Honestly, Your best bet would be to pair a portable DAC/amp with a small external battery bank. Something like this from Anker can stack easily, while also providing fairly decent charging speed and capacity.
Apr 13, 2022 at 1:18 AM Post #4 of 7
Oppo HA-2. I have an extra HA-2SE if you are interested in one.
Apr 28, 2022 at 3:50 PM Post #6 of 7
A megatron with a powerbank.
May 3, 2022 at 1:33 PM Post #7 of 7
This would work but requires AC charger.
However, you could Jerry-Rig it with a portable pocket charger. For the money it sounds pretty good, but there are obviously more higher end portable DAC/AMPS.
https://www.amazon.com/dp/B08B38C3G8
