gshan
- Feb 11, 2005
1) can the Nano battery be replaced by Apple?
2) in/out of warranty, does the battery need to be completely dead (unit doesn't even turn on) before they will do the replacement. -or- can you complain that the battery life is super low after so much usage and would like to replace it?
Thanks.
-S
Thanks.
-S
