iPad 1 + CCK, how to avoid "devices uses too much power"
Nov 26, 2012 at 10:07 AM Thread Starter Post #1 of 1
Angular Mo
I have searched this site and the Web, the proposed solution of attaching unpowered USB hub does not work for me when trying to connect a Fiio E17 Alpen device. Yes, I turned off USB Charging on the E17.
I am hoping to obtain definitive advice on what to do.  I found a site that suggests using ifile.ipa, which I am unable to install via iTunes.  One site suggests using install0us to do this.  Before I go ahead and do this, I would appreciate some advice.
My goal is to play high-resolution files, such as FLAC.   I recently installed Max on my Macbook pro, and FLAC Player app.
Thank you for the help.
-Mo.
