Actually, that's not quite true. I always thought they didn't leak any too, but my officemate could clearly identify Neutral Milk Hotel playing on my e3s a couple of months ago as I walked into the office. The foamies were old, so I'm guessing my seal may have been less than perfect. I would guess that there may also be a small amount of leakage with some of the less isolating tips.
Nonetheless, sound leakage will be a lot less than with just about anything else.
Actually, I'd guess that this would be a good way to check if your getting a proper seal with your IEMs or not. See if someone standing near you can hear any leakage with you using them at sane volumes.
Assuming you have a proper seal, you would have to be listening at a fairly loud volume for any sound to leak out. If I have mine out completely, there is a lot of sound leakage. Just by putting my finger over the hole in the tri-flange of my e5c's, the sound pretty much goes away. I have to put it directly against my ear like this to detect any leakage.
Naturally, there will be some leakage, but definetly the LEAST of any other method of listening.
