Kryton
- Jan 3, 2008
Yep I was the idot. If your new to this like me where do you start. Here are a few tips following my own experiance that might help.
First blow that budget on good headphones (leave a bit for a decent headphone amp). As I write this I'm plugged in to Sennheiser 650's with little dot 1 amp (happy as pig in s**t). My budget was $500.00 for amp and headphones
Pick out a half dozen of the top cans from reading reviews and forums.
Research and find a true enthusistic local hi fi dealer (check his demo's are burn't in I found a huge difference after 40 hours use). Take down your reference tunes. If you do buy on line remember that helpful dealer and buy a few items. I bought on line as price was too good but bought leads and a few cd's from the dealer.
Remember what your after. Arm chair listening or portability. Personnely I spent $50.00 for earbuds, $350.00 on comfortable over the ears Senn 650. My amp is portable so I can take my Senns on road trips.
WORD OF WARNING: You will get hook.
Well gotta go looking into tube amps. Any suggestions.
PS First time on any forum be gentle.
