Laurixas
- Sep 7, 2013
Recently i moved from winamp to foobar2000 and i am lost what to use. i got a plugin for direct kernel streaming. i heard its make playback bit perfect. also i set output bit depth to 24bit. i also downloaded sox upsampler but for example if my musis is in 16bit 44.1kHz should i use 192khz upsampling or 4x to be in 44.1*2*2? or maybe i should use that upsampling at all? yes before you asked i use external DAC: Asio Xonar U7. i set settings to 192kHz and 24bit which it maximum it supports. i heard rumors that DAC this way not work up to that quality but also upscales music and sounds to that settings. is that true? or maybe not all DAC's do that? so please tell me it upsamples or not? and depending it does or not should i use software upsampling alone/together? bit thanks to those who will help me
