How to Rip audio CD tracks to FLAC
Mar 25, 2007 at 12:03 PM Thread Starter Post #1 of 23
bloodandsoil
How do I rip my audio CDs into FLAC format?
I'm running Windows XP btw. Is there a way to do it from the Windows Media Player interface?
And once I have ripped my FLAC files, how do I convert them to Ogg Vorbis? Thanks.
Mar 25, 2007 at 12:09 PM Post #2 of 23
There is so much information about this on the Internet already in the form of ripping guides, etc. that it probably would be most efficient to do some Googling on this subject.
For a start, it might help to narrow the software choices down to some known good ones, such as EAC, PlexTools Professional (if you have a Plextor drive), foobar2000, and dBpoweramp CD Ripper. All of these will let you rip directly to FLAC via plugins, etc. There are also many options available for transcoding FLAC to Ogg Vorbis, but I personally find foobar2000 to be the best (at least the most flexible) transcoding and library management tool.
Good luck.
Mar 25, 2007 at 1:25 PM Post #4 of 23
Originally Posted by JES /img/forum/go_quote.gif
Program called CDex is very easy
x2 for CDex
In my MS Windows days, that one was my favorite CD ripper.
Mar 25, 2007 at 1:45 PM Post #8 of 23
Don't know about your first problem, but for your second, go to Options -> Settings and the Encoder tab. FLAC is the last option in the drop-down box. Use compression level 8 for sure.
Mar 25, 2007 at 1:54 PM Post #10 of 23
I'm using CDex version 1.51. In the Options menu, there is no "Settings".
I did find a "Configure" button on the right-hand side of the app. And from the CDex configuration dialog, there is an Enconder tab. Within that tab there is a drop-down menu, but there is no FLAC option.
Apr 2, 2007 at 3:32 AM Post #14 of 23
Originally Posted by bloodandsoil /img/forum/go_quote.gif
When I launch CDex I get an error "Failed to load the wnaspi32.dll driver! Use the Native NT SCSI library driver option instead?" What is this all about?
You need to download this dll according to some documentation I read about EAC. For EAC, you put it in the EAC install directory, C:\Program Files\Exact Audio Copy . I assume for CDex, put it in the CDex install directory.
ftp://ftp6.nero.com/wnaspi32.dll
Apr 2, 2007 at 3:46 AM Post #15 of 23
i use dbpoweramp with accurate rip.
