How to convert 2 channel audio to multichannel audio...
May 15, 2005 at 5:24 AM Thread Starter Post #1 of 4
heda_p
hi all,
I recently bought CREATIVE INSPIRE 6600 6.1 speakers. My motherboard is
A7n8x delux rev 2.0 (it supports 5.1 channel sound with soundstorm
technology).
I am using latest nforcedrivers_637 for windows 2003. Configured and
tested speaker wizard that 5 speakers + subwoofer are just working
fine. For testing I used nswap utility
Problem is I am having PCTV streo tv tuner card and not able to play 2
channel volume to all the speakers, it only comes from from front left
and front right speakers.
Same issue is with MP3 music also I am using musicmatch 10 for playing
audio...
I am using powerdvd 6 for playing 5.1 channel dvd's and they are
working fine and output is coming from all 5 speakers + subwoofer. I
have configured powerdvd to use CLMEI2 to configure speaker setup to
6.1 channel and it just works fine...even 2 channel dvd's or MP3 are
palying cool with this software...
Though powerdvd is not the configurable for mp3 thus not very
convinient...
question is simple is there a sowtware which converts 2 channel audio
to 6/7 channel audio....
or
is there any mp3 player which has the capability of converting 2
Is there a way I can use all speakers while playing TV on my box?
There ia a hardware decoder creative ddts100 is available, but i don't
want to invest in same...
Kindly let me know how you guys are handling this...
Prakash
India
My current setup is
Windows 2003 Enterprise Server (Evaluation) (SP1)
Athlon 2000 Processor
A7n8x deluxe rev2.0 motherboard
512 DDR Ram
17" Viwesonic monitor
PixelView All-in-ComboTV 128 PCI + remote (This TV works only in WinMe
& Win98, Thus useless for me) Using AGP card 4X Capabilities only.
Pinnacle PCTV Stereo TV tuner card
Samsung Combo drive
BENQ dvd writer 1620pro
Cretive inspire 6.1 speakers.
160GB Seagate Sata + 120 Gb Samsung pata + 60GB Western Pata
May 15, 2005 at 10:39 AM Post #2 of 4
Your problem is that you'd need some kind of upmixing software. This, however, has nothing to do with hi-fi any more since obviously it's not defined anywhere how to distribute 2ch content across 5.1ch. Doesn't the Soundstorm software offer something?
May 15, 2005 at 12:01 PM Post #3 of 4
You could always utilise the Foobar stereo to 4 channel.
The other one I use is via my Marantz receiver which outputs to prologic 2 and that is sufficient at the moment.
I will search and update post if I come across new information.
Google for now is your best friend.
EDIT: OK update, do a search for CMSS, it is a creative software meant to work with creative hardware, I realise that i might mean investing in a creative soundcard, but from my last trip I remember them not being oo expensive in India. That is a good option, haven't discovered much else. will return if more stuff found.
