Crowbar
- Jun 23, 2006
How much copper would one expect on average in the motors and wiring of an electric car (in kg)?
Originally Posted by Crowbar /img/forum/go_quote.gif 100 kg would be a reasonable estimate (a Prius hybrid is about 50 kg copper). |
Originally Posted by Trippytiger /img/forum/go_quote.gif Nope. Try this: the very powerful motor in the Tesla Roadster weighs in at around 70 lb/30kg. That's the total weight, so the weight of the copper is obviously going to be even less. The average commuter's car has no need for that kind of power, so the weight of the motor (and consequently, the weight of the copper) in most all-electric cars in the future would be even less than that. |
Originally Posted by ilikemonkeys /img/forum/go_quote.gif Good point, however the Tesla has one of those motors per wheel. That's why it's so fast. |
Originally Posted by AlanY /img/forum/go_quote.gif I'm calling BS on the idea that an enormous amount of extra copper is used in the Prius. If so much extra copper was being used over a regular vehicle, the price differential would be much larger than it is. And where is all this extra copper being used? The battery is NiMH -- no copper. |
You could just as easily use aluminum wiring in the electrical motor as copper. |
Originally Posted by Crowbar /img/forum/go_quote.gif I've come across this number several times. For example: Resource Investor - Interviews - Nothing Like it on Planet Earth - Robert Friedland's Tour d' Tolgoi "The Toyota Prius, which I just came from Nagoya, I had a tour of this factory with senior management from Toyota, uses 50kg of copper per car. By the way, they don't need any gold to make these cars. 50kg of copper per car is more than twice as much copper intensity per unit car as a conventional car." |
Originally Posted by Crowbar /img/forum/go_quote.gif Bull! I already addressed this point in my post. Bother to read before replying next time, chump. |
During the 1970's, aluminum (instead of copper) wiring became quite popular and was extensively used. Since that time, aluminum wiring has been implicated in a number of house fires, and most jurisdictions no longer permit it in new installations. The main problem with aluminum wiring is a phenomenon known as "cold creep". When aluminum wiring warms up, it expands. When it cools down, it contracts. Unlike copper, when aluminum goesthrough a number of warm/cool cycles it loses a bit of tightness each time. To make the problem worse, aluminum oxidises, or corrodes when in contact with certain types of metal, so the resistance of the connection goes up. Which causes it to heat up and corrode/oxidize still more. |
