yfei
- Jul 1, 2002
anybody have experience with it? Can it properly drive HD580?
lowest price is about $190 + shipping
http://www.m-audio.net/products/m-au...iophileusb.php
Audiophile USB is the affordable, no-hassle USB audio and MIDI interface for Mac and PC. The Audiophile USB builds on the success of our popular Audiophile 2496¡ªawarded Best Soundcard by Computer Music magazine¡ªdelivering 24-bit/96k quality with great dynamic range and noise specs. That¡¯s because it uses AC-powered components that deliver better fidelity than bus-powered circuitry. The included Mac and PC drivers let you independently scale bit depth and sample rate (up to 96k) to deliver the lowest USB latency anywhere¡ªwhether you¡¯re on stage or in the studio.
specifications looks even better than Audiophile 2496:
Analog Audio:
Peak Signal, Analog Input: +2dBV
Peak Signal,Analog Output: +2dBV
Dynamic Range, Inputs: 109dB (A-weighted)
Dynamic Range, Outputs: 107dB (A-weighted)
THD (at 0dBFS): -92dB (typical)
Frequency Response: 22Hz - 22kHz, -0.4,-0.4dB
Maximum Converter Data Width: 24 bits
Input Impedance: 10k ohms minimum
Connector Type: Gold-plated RCA female, back panel
Digital Audio:
Digital Input Sample Rate: 8kHz to 96kHz
Maximum Word Width: 24 bits
Digital Input Format: S/PDIF coaxial, 0.5 to 5V peak-to-peak
Digital Output Format: S/PDIF coaxial, 0.5V peak-to-peak
Digital Output Sample Rate: 8kHz to 96kHz
Data format: S/PDIF (not AES/EBU)
Connector Type: Gold-plated RCA and 1/4¡±, female
MIDI:
I/O Configuration: 1-in/1-out (16 MIDI channels, in & out)
Connector Type: Standard MIDI 5-pin DIN
Analog Audio:
Digital Audio:
MIDI:
