razvitm
- Jan 21, 2011
Some of them have built-in sample rate converter, they accept both 44,1KHz and 48KHz optical spdif.
You can fool the player that you want to record, it starts converting the digital stream and outputs audio to line-out so you can set recording levels, and you keep the player in this state, you don't start the actual burning of the disc.
I'm at work at the moment, but when i get home i will try this with my sharp and sony minidisc players, maybe run some RMAA tests on them, to see how they compare to my Fiio X3 portable DAP and DAC.
The thing is they are battery powered, battery lasts long, there's volume control while converting, maybe even bass boost.
Did i mention remote control?
