marchmadness
- May 5, 2011
I just recently bought an R6 player and had a few questions about the SD card tray and SD cards. When you push the pin tool all the way in does the tray pop out? I have to wiggle it around to get it out.
Also I've tried inserting 2 brand new SD cards, but the R6 doesn't recognize (see) either of them. I know these are good cards. I'm assuming I would format them while inserted into the R6, but I can't since the device can't even see them.
When I try to remove the tray with card in, it's super difficult, so much so that I stopped trying to test different cards. Is there a trick to this? Did I get a defective unit?
Everything else works fine. I updated the R6 to Oreo as soon as I got it. Thanks in advance for the help!
