Alright, so I just got the Cayin HA-3A and I love the sound...of music ha! I'm getting terrible hum and buzz. I thought it was from my Bifrost 2/64 USB connection as I get worse buzzing when I move my mouse on my desktop through my headphones. I'm sure that's also part of it.
Last night after hours of researching and reading, I decided to unplug all sources from the amp and just have it plugged in to the Furman Surge Protector that I have. Well, buzz was still there and plenty loud. It's the worst on SE and XLR output and not as bad on 4.4. Makes sense due to the power draw. I even tried another outlet in a different room...again cheap electrical work is obvious.
I know this is not the amp because my Bottlehead Crack exhibited this issue too. My electrical in my house I'm sure is not the greatest. Hell we run a vacuum in another room and sometimes a light in a separate room dims for a sec. House was built in 2019 but these houses go up so fast I'm sure there is no extra quality put into the electrical work........but I digress.
So now I'm trying to decide upon the least costly way of helping my issue. I've bought a better USB b cable for my DAC to hopefully cut out some extra noise from the PC. Do you guys think I need a Transformer Isolator? I've read about those on other posts but it's been a while. I've also seen things like HumX and such that just adapts to the power to the wall.
Follow up to that also: can a transformer isolator be plugged in and then the surge protector to that so I can have my PC and other audio components to it, or is that a no no? I'm sure my PC has the same ground issue which would mean getting a ground fix to the amp may not resolve all the issues.
To be clear, this just happens to my tube amp. Every so often I will notice it on my iHA-6 on the SE connection but never the XLR. Again it's power draw I'm sure.
I'd appreciate any advice!
