bcwang
- Feb 28, 2003
I've got a D500se but the tray has been degrading lately.
Starting months ago, the tray would be stuck closed most of the time, if no disc was in it, and would require a tap on the cd player to get it to eject. If there is a disc in it, then it will open every time
More recently, discs will go in, but it will not be fully seated and after a few seconds pop back out. It got worse now that it happens almost every time and needs a good hit to get the disc to stay in and load.
The most recent, even when the tray is fully open, the close button will make the motor try to move but the tray won't move. You have to help with your finger to get it to go in.
So does anyone have any ideas how I can fix this myself? The player is out of warranty and I don't think hitting it everytime can be good for the electronics. Is this a common problem with Cambridge Audio players?
Thanks!
Thanks!
