Stu Clark
Hello there,
I’m sorry to ask but I thought this would be the best place to ask for help as I know the focus here will be solely on sound quality…….
I have connected the Node to the Qutest via the COAX on the Node & using the BNC on the QUTEST in order to bypass the internal DAC on the Node.
But……. I obviously want to get the best quality & also from MQA.
In your opinion’s should I alter the settings or should I leave them because the device should be automatically playing at the best resolution without unfolding the file?
I remember seeing some advice online that states “Disable Tone Controls—Disable Replay Gain—Enable Iutput Level Fixed—Enable MQA External DAC”
However I am concerned that I may be then tampering with the quality of ‘non MQA’ files? I have no idea really.
Attached is a pic of my current settings.
If anybody could throw some pointers I would be grateful! Oh, I also set my Node volume to High so I am not using much range on my amp as it has a dial (Accuphase).
I hope this was clear .
