Help - Topping A30 Pro has blinking white light and relay shuts it down
May 28, 2025 at 3:45 AM Thread Starter Post #1 of 3
gilkinted
UK
I have the problem of a non-functioning A30 Pro which either needs to go to China and back or get fixed here. Does anyone know of a Topping repairer in the UK?
Thanks in advance,
Allan
May 28, 2025 at 4:26 AM Post #2 of 3
It would take a local repair shop, Topping doesn't have any repair places outside the factory in China. The last thing I'd try is unplugging it for 8 hours to drain the capacitor and see if it resets. It's a long shot but replacing the power cord is worth it if you have a spare. There's ground and lift mode to switch to, just to narrow down everything before sending it back.
May 28, 2025 at 1:15 PM Post #3 of 3
Thanks for your reply. I suspected as much on the repair front. I did all you suggested but historically it seems to be a power supply issue which sends the protection relays in to apoplexia!
Thanks again.
Allan
