Thugsheep
- Feb 7, 2015
Hey all,
Looking forward to becoming a part of the community!
I've read a lot of great information on here about audio setups which has allowed me to grasp onto the basics. My concern now is having a suitable microphone setup for streaming games and voice overs. I've decided to go with the Mod Mic 4 as opposed to the condenser type mics (e.g. AT2020) simply because I'm really tight for space and couldn't afford the extra room for a decent stand; an important piece when considering voice isolation (reduce background noise).
Taking all this into consideration, are there any audio interfaces or mixers which a 3.5 mm mic could benefit from when looking at sound quality? I've listened to various reviews of the Mod Mic 4 and there does seem to be a spectrum in quality which leads me to believe there are other factors in-play.
Research has led me to this USB mixer:
http://www.behringer.com/EN/Products/302USB.aspx[1]
It has a 3.5 mm input designed for use with headsets-- would this improve the sound quality coming from a Mod Mic 4 or any 3.5 mm input mic?
TL;DR: Any audio interfaces/mixers that could improve sound from Mod Mic 4 (3.5mm input)?
