auvgeek
- Aug 8, 2014
I have an older USB DDC from Breeze Audio that used to work well. Pretty sure it's XMOS. I'm using it to feed an older Theta DAC that doesn't have USB.
I haven't used it for a while and now I can't seem to get any playback device to recognize the DDC for audio out.
I have tried two windows laptops, a linux laptop (ubuntu), and an iPhone via a lightning to USB adapter. I'm pretty sure the DDC used to work with one of the windows laptops and the ubuntu laptop. I have tried multiple USB cables. None of the devices recognize the DDC as an audio output option, and linux does not recognize a USB connection when when I run "lsusb" on the command line.
On the DDC side, the red power light comes on and the green USB light comes on when the USB cable is plugged into an external playback device (laptop, phone) ... so the DDC can definitely recognize when it's connected to a playback device.
I'm not sure what to try next in terms of driver downloads or what. It seems like a software issue because the green USB light on the DDC comes on when a USB cable is connected, but I'm not 100% sure how to rule out a hardware issue.
Any thoughts?
Any thoughts?
