Help needed! How to disassemble fiio e7?
Feb 14, 2011 at 8:34 PM Thread Starter Post #1 of 9
silentx09
Hi guys!
I need help in disassemble fiio e7. If i removed the screw at the back but it seems that i don't know what to do next to get access the inside of the amp. Has anyone have any experience in openning the fiio e7? Do teach me how.
Thanks in advance! =)
Feb 14, 2011 at 9:49 PM Post #2 of 9
That's going to void the warranty; why would you want to do that? It's not like you can roll opamp.
I think when the screws are unscrewed, you should be able to open it up easily.
Feb 15, 2011 at 11:04 AM Post #5 of 9
Looks like he'll do it anyway.  May I ask what you are planning?
Try using a very thin/small flat-head screw driver to pry open the casing after removing the screw(s).
Also, look for any tabs that may be helping the case stay shut.
Very carefully, do not use too much force so you do not damage it.
Take your sweet time.
Feb 15, 2011 at 5:52 PM Post #6 of 9
8091a150_404030
Source
Hope this will be of help to you.
Feb 15, 2011 at 8:00 PM Post #7 of 9
thanks guys i am trying to figure out how to open, as i tried removed the screw at the back but it seems tat the back cover is really hard to open.. is there any tools or tips to open it?
One of my 3.5mm jet the side connector has bend inwards to the fiio e7, thus i bope to open it up and bend it back to its original position so tat i can use it again. =S
