Help Needed: Battery Draining Problem on iAudio X5
Oct 30, 2007 at 4:29 PM Thread Starter Post #1 of 3
rayq
Hi, does anyone have the similar problem that I am experiencing for the iAudion X5 battery. The battery is being drained right after fully charging; I have to charge it again the next day after using it for ~one hour. I have tried to perform the DIY battery replacement with the LG battery. It did the same thing with the new replacement battery. After fully charging, the battery indicator showed only 90% full though. I am suspecting there is something wrong in the unit itself. I will greatly appreciate any advices. Thanks.
Raymond
Oct 30, 2007 at 7:40 PM Post #2 of 3
how old is the battery, and has it ever been repaced?
Oct 30, 2007 at 8:14 PM Post #3 of 3
I have replace the LG 8120 OEM Battery and it seemed to perform the same problem. Thanks.
