Help me with the EQ settings in my Zen Micro
Jan 28, 2005 at 7:46 PM Thread Starter Post #1 of 11
AManInJapan
How should I set the EQ to get the best sound for EX71's?
Also, what does "Smart Volume" do?
EDIT: Wow, the "Vocal" setting sounds awesome! It gets rid of the "screechy" sound and tones down the bass a little.
Jan 28, 2005 at 8:49 PM Post #2 of 11
just got my zen micro as well so i don't know all the feature as yet. be aware there is a Manual in a PDF file for the micro on the CD which will provide answers such as yours. as far as EQ setting for your SR-71, it seems you already are well on your way to finding out your own EQ preferences which is the best way to find out.
as far as i gather the Smart Volume allows you to listen to all you music at a set volume which would be helpful if your songs/ albums have been recorded at different volumes levels and saves you the effort of adjusting volume from one song/album to another. i don't bother to use smart volume.
Jan 29, 2005 at 1:12 AM Post #3 of 11
I LOVE the smart volume and i wish to high heaven that all audio/video players had it. its so anoying having to adjust volume all the time especially if you cant avoid it because you download illeagally
Jan 29, 2005 at 1:53 AM Post #4 of 11
people have said that smart volume significantly decreases battery life. something to watch for if youre using it.
Jan 29, 2005 at 3:38 AM Post #5 of 11
i'm currently testing that theory and will have the results at the end of the weekend
Jan 30, 2005 at 12:54 AM Post #8 of 11
Originally Posted by mightymouse
how would i adjust my eq for a bass boost?
using the custom eq, the left is lower frequencies and the right is higher freqs.
Jan 30, 2005 at 2:34 AM Post #10 of 11
so would a V looking (left high, gradually lower to middle, then higher again) eq be good for bass and treble?
yes. that's what mine is set as. on things without an adjustable eq i usually use the 'rock' setting, which is pretty much a V. i tried to use it as a bassline and adjust from there
Jan 30, 2005 at 7:13 AM Post #11 of 11
Originally Posted by Pasty
just use a normalizer to normalize all your mp3s before you transfer them to your player.
do you know of a good volume normalizing program? and if so what db level should i level too?
