Blasted
- Feb 14, 2008
Hello,
I'm new to head-fi, even though I've been lurking around for a while, which made me learn quite some interesting stuff, specially regarding amps and phones. I'm now looking for a new MP3 player to replace my OLD MuVos (I needn't a MP3 player for the last years, until now).
The MP3 player I'm looking for needs to work both as a portable, daily player to use in commutes home-work, but also to work as a "normal" bedroom audio system, resting attached to a dock with decent-sounding speakers. I don't need anything top-notch regarding the dock part, just something that can play some background music while I'm lying around in the bedroom, and some loud sound in the morning to wake me up. This said, a crucial function I need is the Alarm Clock.
Update: I'm also going to use this MP3 player with a Mini3 amp connectec to a 2.0 stock car audio speakers.
I'm willing to fork something around 80-100€ for this player. I might go a little over this value if I can get really cheap speakers/dock to use it with. Obviously, I'm looking for the most bang for the buck
Basically, by order of importance:
.Portable MP3 Player
.Good Sound Quality (something worth of using with KSC-75)
.Alarm Clock function
.File Folder Browsing
.Possibility to use with a docking station with decent SQ (looking for recommendation on which dock/speakers too)(I might just buy a simple decent 2.1 speaker system and plug the MP3 player there)
.FM Radio
.2GB disk space (at very least)
.Easy to navigate through songs
I can't test any of the MP3 players around here before I buy them, so I really appreciate any and all advice you can give me. I'm also looking for some suggestions on the "docking station" to get along with this. Thanks!
.FM Radio
