The manual is indeed very handy:
http://www.curcioaudio.com/st7_mnl.pdf
The 7199 tubes are the biggest problem with that amp (and with a number of other amps from that era including HH Scotts). Modern makes of EL34s are great, comparable to the old ones and well worth using, but the 7199 is no longer made (if you see Sovtek-branded "7199," don't use them; they're not). It sounds like you have a good stock of the old ones. Those Dynaco-stamped ones are most often RCAs, which are very nice, but Sylvania are also great. Keep in mind that they don't last forever, though (if you see a lot of stuff that looks like scorch marks inside, it's probably time to change them) and fresh ones will improve your amp's sound considerably. Then you face a dillemma: The NOS ones cost upwards of $25 each. For that price, you can get the driver board replaced with a new one that uses better, cheaper new triode tubes like the ECC99. (Triode Electronics in Chicago sells a great one).
The rectifier tube you've got should last forever, or at least a very, very long time. You don't need to get too excited about 5AR4s -- they're rectifiers, and they either convert AC to DC or they don't. For a long time, the modern ones (incl. Sovtek) had a tendency to fail after short periods (like a year). There are more brands now, and maybe some are better. Still, this is a case where buying an old one, even used, was probably wise. The old rectifier tubes just keep on ticking.
It really is a great sounding amp with new components, though... I like its sound better than the bigger MKIII -- it has a comfortably low operating point, with plenty of class A operation, and very modest feedback, and most importantly it has really fantastic output transformers (which saturate just a bit on the low bass, giving it that plump-bottomed sound). As Sheldon Stokes said, it has a loose-tailored sound, like a comfortable old shirt, rather than the starchy sound of other amps.
