Ziraxus
- Apr 6, 2017
Hey
I am looking for some headphone / headsets which I can use for 8-10 hours, without feeling uncomfortable after set time period.
After using headphones / headsets for a long time, I start getting a slight headache due to the pressure applied by the headphones on the ears.
So I am looking for, yes, headphones / headsets where you can use them for 8-10 hours-ish.
Budget range is 100-200€
I've looked at some Sennheiser 598 / 600 / 650, first one doesn't sell in my region. The two others goes for about 400€ in my region, way too expensive for me.
So I am basically looking for something cheaper than those. - Note: I am not interested in buying "used" headphones.
That said, I would prefer if it was headsets, with a mic & cabel. (Preferable cardioid mic) - But I've head comfort-ability & headsets doesn't go hand in hand.
If I am to buy a headphone without a mic, I'll have to buy a mic separately.
I hope you can help me.
